1 - 14 of 14 Posts
you put a shim on the samurai spindle it wont seal correctly.
sure it can for say the rear of a dodge caravan where the spindle is solid and has no driveaxle through it.
In reply to:
no, you would put a shim between the spring and spring pad
[/ QUOTE ]
This changes caster. (Angle of the steering axis from vertical.)
Camber is the tilt of the wheel in/out from top to bottom. Non-adjustable according to the FSM....
1 - 14 of 14 Posts
