Cam Bolts for upper control arms for 97 TJ's
531 Views 2 Replies 2 Participants Last post by  peteyg
Cam Bolts for upper control arms for 97 TJ\'s
with my budge boost on my Tj i still get a slight vibe at highway speeds, just wondering if getting new cams thats adjust the angle 2 or 3 degrees would fix that, they are about $30 bucks for the set anyone try these, or know of where to get them cheaper at? thanks
Re: Cam Bolts for upper control arms for 97 TJ\'s
first I'd check tire balance and then I'd suspect the rear slip yoke....
the cams wont ususally fix vibes
They're a real pain in the a$$ to install, too. The instructions say "knock the tabs out of the mounts..." Yeah, right. In all the installs I've done, only ONE knocked out. The rest I had to either drill out or punch out with an air hammer.
Try the above fixes first. A SYE w/a CV rear DS works wonders.
