I am curious, what would entail making a C6 for a 460 2 wheel drive to mate to a NP205? Is it just the tail shaft or is it there far more to it. Let me know...
Don't bother with AA, why get an aftermarket part when a FACTORY part is available?
I did excatly the same... Since I needed it rebuilt anyhow I took a 460 2wd C-6 and a 351 4wd C-6 tranny and had the guts swapped. You could just get a tranny and have them swap the guts if you want. I also had the AOD gear set installed which game me a 2.72 to 1 first as opposed to the 2.46 to 1 first in the stock C-6.
The C-6's came with a 5.25" and 8" tailshaft. If you are putting in a Fullsize Bronco like I did, you need the 5.25 shaft. The NP-205 will bolt right up to where the NP-208 does. I have a NP-205 ready to go in once I grenade the NP-208.
Any more questions feel free to ask..
Uzi... Yamaha Sleds, Honda Bikes, and Ford Trucks
You mentioned an AOD in the C6 tranny? Forgive the question but you can get an overdrive added to a C6 tranny?
thanks for any additional information.
Ok.. true.. my mistake.. I will further Clarify what I meant by AOD gear Set.
You can Swap in the 1st and 2nd ONLY gear set from an AOD tranny.. obvioulsly the 3rd gear in an AOD is 1 to 1 and the 4th is overdrive.
There's a nice article in July 2001 Peterson's 4Wheel&Offroad on page 28 about a nice build-up of a C6 using the E4OD 1-2 and reverse gear sets. JET Performance Products did the work. Pretty slick.....
