Ever built a cj frame?
Ever known anyone who has?
Call me.
I need help to build a cj8 frame. 2x4 inch tubing, can it be done?
coot.
sure can... i dont know anyone who did.. but i could tell you if i had the tubing and welder i could do a 7's frame.. if you have a haynes manual for it.. it should have the dimensions in the back..mine does for my frame.. i saw that and was like wow.. i could build my own with that.. now where the hell is that welder?
hey i tell you what you come get the fram out of my back yard you can have it it is from a 79cj7 and has one bad spot and it is small.. it is yours you can have it.... that will make life easy for you
hey i tell you what you come get the frame out of my back yard you can have it it is from a 79cj7 and has one bad spot and it is small.. it is yours you can have it.... that will make life easy for you
