A friends D60 cast in spring perch has a broken bolt in it. Probably a 5/8 or 9/16 grade 8 bolt. He has already drilled a 3/8 hole in it that is a bit off-center and tried an Easy-Out with no luck. The hole can not be drilled any bigger without ruining the thread. What other options does he have? What would be the best way to try to cut a vertical slot into the bolt stub from the inside? That way it could shrink some more once heat/cold is applied. Inventive ideas welcome. We've already tried C4...
