71-75 flanged axel 44's should have a vent nipple on the drivers side of the axel. The vent tube allows for the expansion of the air/hot hot vs. cold and helps keep the seals from sucking in water.
Could someone have attached a brake line mounting bracket to your hole?
you could drill and tap a hole
