Breaking the Bead
1.5K views 3 replies 1 participant last post by  **DONOTDELETE**
I need to break the bead on my 31" tires, which are still on the stock rims. America's Tire Co wants almost 10 EACH to take them off the rims!
Someone told me I could place the hi-lift on the tire (while the tire is laying on the ground), place the tire underneath the vehicle and jack it up, with the hi-lift on the tire... This seems like it would do a LOT of damage to the tire (they're almost new, and would rather sell than fry!) Ideas welcome...
How much are tire irons (is that the right term?) thanks!
jp
http://www.obsessiveoffroad.com
If you don't stand for something, you'll fall for anything...
In my youth on the Navajo Reservation while runnng first the Teec Nos Pos Texaco and later the Shiprock Shell Station, I think I've seen it all when it came to tire patching, jimmy rigging and working without proper tools in general. We even did truck split rims with curved chizels, tire irons and a sledge hammer. Whew!
We hot vulcanized inner tubes in those daze! Tubeless was new then. That'll date me.
The jack base will probably work and won't generally hurt a tire if it doesn't have a really sharp edge.
You can even try popping one by jacking your Jeep up and put the rubber of the wheel under a tire and jack the jeep back down on it. If the vehicle mounted wheel has a decent edge on it, you can pop a bead that way sometimes.
I've even poped them by rolling over the rubber ... but it helps to have a spotter do do this ..
The edge of a bare rim on the vehicle lowered on the bead will work every time!
You will need two or three tire irons and/or big screwdrivers to pry and pull the ID of tires off the rims after you break the bead.
It doesn't hurt to have a BFng hammer and a little soapy water on hand either.
BTW: The classic "tire iron" .. you know, the dog leg shaped bar with a lug nut socket on the short side and a screwdriver shaped flat on the other...that came with most pre '80's vehicles ...
And you just always thought that end was just used to pop the hub cap ...
The specifically designed tire irons also are flattened but have a 'wave' in them to help you get the end of the bar under the lip of the bead.
JAF
