braking pull???
469 Views 4 Replies 1 Participant Last post by  **DONOTDELETE**
any one else have this problem? brake hard and the jeep pulls to the right. actaully braking hard is like stopping a big rig..:-(
It could be your brake proportion valve, rear brakes are not adjusted correctly, weak front suspension parts and road surface (maybe).
Good luck,
[email protected]
Could also be that your rear shoes are worn on one side more than the other. Or your drums might be oversize on one side. Could also be a stuck or sticky. caliper.
Hello Matt
I had the same problem for a long time, no-one could solve the problem, freinds, brake shops, etc... I replaced all the brake lines in the frame last winter and comes to find out that I had a line pinched between the frame and the front crossmember, when the frame flexed it crushed the tube about 50%. It happened to me it could happen to you, who knows?
Just something to think about, Good luck.
Bill
thanks for the replies. i appreciate the help.
