Guest
·I own a 1987 Cherokee 4WD and just replaced the power brake booster, master cylinder, front brake calipers, pads and turned the rotors. Also adjusted the rear brakes. Light braking seems to work fine but under heavy braking the vehicle doesn't stop well. The pedal isn't spongy, it feels normal but you must push the pedal past the booster assist range with significant pressure to stop quickly. Even then it requires too much pressure. Any thoughts?
Thanks very much for the help.
Mike
Mike
