I will be converting my 99 super duty dana 60 front to an 8x165 lug pattern with a custom-built hub. What I am trying to find out is what brake rotors can i use that will match the dimensions of the stock ones but will keep the new bolt pattern.
As far as my research goes, the stock rotor dimensions are:
38mm Rotor Thickness
99.5mm total width
https://www.autozone.com/brakes-and...rotor/p/duralast-brake-rotor-54078/352144_0_0
The aftermarket one that I am looking at has the dimensions of:
35.5mm Rotor Thickness
101.9 total width.
https://www.autozone.com/brakes-and...rotor/p/duralast-brake-rotor-53012/629609_0_0
Will this aftermarket one fit and clear the hubs, calipers etc. so I can use it with my custom front hubs?
I am unsure how the small differences in thickness will affect fitment and such.
-Thanks
99.5mm total width
101.9 total width.
-Thanks
