I have a 2008 Arctic Cat prowler that makes a bad noise when I use the brakes. I was told to let the center brake wear and it should stop. I have contacted the dealer again and he said that Arctic Cat is taking each problem
and looking at it. Has anybody had this problem before and what is the fix?
Duckslayer
Pad or caliper
Has to be one of three things:
THere's something stuck between the pad and the disc, the pad is loose or sticking, or the caliper is stuck compressing the pads against the disc.
www.sbsparts.com
