Body mounts
448 Views 1 Reply 1 Participant Last post by  **DONOTDELETE**
I want to install Daystar's 1" body mount lift. I have 85 cj7, but some of the current mounts don't exist anymore, specificaly the front end. Does this kit come with instructions and diagrams at all? I saw that someone mentioned they used the kit. How was it?
also, what do I do if areas around the mounts are rusted through?
This is the first of many questions to come I'm sure. I just found this excelent site.
Sean
The Daystar kit replaces all mounts with ones that are 1" longer, If you have rust on your tub at the mounts I would try and get them fixed before putting on the new poly-bushings. they flex less than OEM rubber, so this could cause problems if you dont get rid of the rust.
