This is a 4.0L YJ. My brake lights work, left blinker works, right blinkers stay solid when activated. Replaced bulbs and turn switch canister, didnt help.
Any idea? This is driving me nuts!
I assume, when you say the right blinker stays on solid, it is lit. What is the front right blinker doing" If it's on as well, I would not suspect a ground problem. If both right lights are on I would suspect the flasher unit itself.
I guess if your'e really stumped, as a last resort, disconnect the wire from the left side and move it to the right side. If the right side works after then it's the flasher unit that's bad.
Hope this helps
Ralph...
Carpe Dium - to make every day count!
Why not just swap flashers on your fuse box?
Can you fix it?
I got a welder and a grinder. Heck yeah I can fix it./wwwthreads_images/icons/cool.gif
