I'm working on my 2000 blazer project that has a leaking right side front diff seal leaking.After the front drive axle is out,is it ok to pull the shaft out of the axle tube,or will parts of the differential fall apart when you do that?The problem is that I'm having trouble getting the new seal started straight and it would be a lot easier if that stub axle was not sticking out of the axle tube.Thanks
