Big Q\'s, please help guys!
1- How can you make a twin stick for the Dana 20?
2- Where can I find a place to build a heavy-duty highangle short c.v. driveshaft, it's going in a CJ-5 with a rear Dana 60 and a swapped in T-18.
3- The rear Dana 60 is out of a J-20 jeep truck and has 30 spline axle shafts, can I just get custom 35 spline shafts to fit in the rear with a new carrier or does it take anything else.
Thanks guys!
Re: Big Q\'s, please help guys!
1- Search the bbs, there has been a couple posts about this, there is a link to an article on one of them. Or you can get the twinstick kit for a D300 and modify it to work.
2- the above mentioned site Tom Woods, or Arizona Drivelines are good also.
3- Dunno
pbm
74 cj5,304,t18,2.46 ts d20,30f,44r,soa,MORE buggy front,35's,Rci's,5pt,full cage,air,etc.
Support Search and Rescue.......Get Lost! /wwwthreads_images/icons/shocked.gif
The spindle bore may be too small for the 1.5" 35sp shafts to fit thru, it may need to be drilled out to 1 5/8" or so...It's not fun (hard steel).
