BFG MT's or AT's??
381 Views 7 Replies 4 Participants Last post by  Pete88YJ
BFG MT\'s or AT\'s??
i'm needing new tires on my YJ and since my last question i'm gonna go with 30 x 9.5's, now the question is, do i go with MT's or AT's i do a little mild off roading and alot of highway driving, so i'm assuming the AT's last long, but what are the Pros and cons with and against the MT's and the At's i just wanna be sure i get the right tire because those are expensive!
thanks a ton!
(\/)ikey 1988 Wrangler Laredo 4.2L w/5spd Manual
1995 Wrangler 2.5L w/ 5spd Manual
1 - 8 of 8 Posts
Re: BFG MT\'s or AT\'s??
After 13 or so years of mud terrain tires I bought BFG ATs summer before last. They are OK on rock when aired down to 10 lbs. or so, and they are good on sand and real quiet on the road, but boy do they ever suck in mud. And, even though they are OK on rock, MTs are mucho better. Anybody want a set of 33x12.50 BFG ATs with about 10k on them? /wwwthreads_images/icons/smile.gif
See less See more
I had ATs 30x9.5 on my YJ when it was stock. I really liked them. I have 33 muds now. If I ever have a street truck or suv I will put ATs on it. The ATs were great in the snow.
I have 33x12.50x15 mt's on my 98TJ. I drive it daily, and they're REALLY loud. They rock in the mud, but are scary in snow and after having them a little less than a year, the tread is half gone. If you do only mild off-roading I'd recommend the AT's, they'll handle on the road better, if you're a hardcore mudder or rockcrawler go with the MT's. Or get both, speaking of which, Brad how much are you asking for those AT's??
Steve
/wwwthreads_images/icons/crazy.gifJust Empty Every Pocket/wwwthreads_images/icons/crazy.gif
See less See more
2
I run 35x12.5x15 BFG MT's. I really like them. I don't think that they are too loud - but then again, I have a soft top and the wind noise doesn't bother me either (kinda compensates for the road noise :). If you do any off-roading, you'll wish you had the MT's. I've had mine for about a year now, and they're wearing great and ride good. They are scary on ice tho! and if it's really wet, you gotta watch it.
- My 2 cents: go with the Mud tires!
Keep on Jeepin'
Scott
We run both tires on the TJ, but they're 31's. In the winter I prefer the AT's, they handle great in the slush, ice, and wet pavement. The MT's will perform well in the same conditions when new, but aren't nearly as good with a few miles on them. They go OK in the deep snow as well. I have run AT's in sizes 215/15, 235/15, 31x10.5 and 265/16 on various vehicles. I routinely get over 60K on them for wear, and one set I have rotated from Scout to Jeep to Jeep for over 7 years, still no cracks or problems. Cjjeepercreeper is right about the mud though, even aired down they're not that great. If you're going to wheel in the sand or rocks, they're OK, but mud is out. They're also very quiet, not that the MT's are loud, they're just louder than the AT's. Traction on pavement is awesome though, whether it's wet or dry.
We wheel frequently with the TJ, so we run BFG MT's in the summer. We tried running them in the winter and found it to be a mistake, so we switched. When the pavement is cold and a little wet, forget about traction unless you're light on the gas. We have had, on more than one occasion, the TJ come around on us during acceleration. We have the 6cyl, 5spd, 3.55's with Trac-Lok, so that probably didn't help, but we were surprised at the difference in tires. They were OK on wet pavement in the summer, don't get me wrong, there's no safety problem with traction overall. The wearability is the same, we got over 55K on the MT's and they'd still take a sticker. The noise is increased a little with the MT's, but with a soft top (or no top), you won't notice a difference, they're not Super-Swamper loud. Off road is where you notice a huge difference. Sand, mud, rocks, whatever, these tires grip, and do it well. They clear well, which is the main problem with the AT's.
I hope the pros and cons I have listed help in your decision. If I had to buy 1 tire based on your description, which would it be? I don't know, really. We wheel with our TJ once a month, pretty hard, so we like the MT's overall, and I'll be buying a new set in the spring. For my Trooper, which only occasionally sees the dirt (camp, hunting, skiiing, etc), I prefer the AT's all the way. Good luck in your decision.
JEEPN
'81 CJ-8 Scrambled!
See less See more
MT's..everyone else has pretty much explained the difference between the 2 so that is just my opinon.
absolutjeep
I run MTs in the summer, ATs in the winter. It snows here in MA, and it gets icy. Plus, it saves the miles on the big MTs.
Personally, I love the noise of them MTs on the road. /wwwthreads_images/icons/smile.gif
More than one post has said that the MTs are not good in winter on ice and water and such. So, if you do drive a lot on that in winter, look at getting a set of winter tires, and get the MTs for the summer.
Good luck
Pete
See less See more
1 - 8 of 8 Posts
