When you break in a new gears set you should do it on jack stands. We run are for just about 30 seconds the first time. That slings the oil everywhere, then while the oil is dripping back down it is getting the the places that didnt see oil yet. After about 5 mins or a beer we fire it off again, just let it idle in gear for about 10 mins. During those 10 mins keep feeling the pinion for heat. It shouldnt get to the point where you cant touch it. When then let it sit till the pinion cools down. Once the pinion is cool we then go another 10 mins. This time changing rpms and appling the brake once and awhile to apply some force to the gears. Once the 10 mins are done lower it down and go for a ride. So how do you break in the front. Just put the shifter in 4 high, the tires will be off of the ground.
Just a thought, dont use your big swampers. You will know real quick how unbalanced they are.
