Re: Bead lock rpogram done
thats a good price, wish they were around when I was shopping. I ended up with Rockstompers (which I'm happy with)
TIPS - put a thin layer of RTV in the inner ring to help seal the tire, I didnt do it to the first one I mounted and it will go flat in about 3 days. I sealed the other 3 and they been holding the same pressure for 5 months.
- before you tighten down the bolts, you can put a fan belt ( I can try to find the size if anyone gives a damn)on the inside ring of bolts, this does 2 things. It keeps mud from building up in there and more importantly, it gives the bolts something to tighten down on. It allows the bolts to get tighter and prevents "coning" of the outer ring.
- Its hard to balance a bead lock, I used 3 golf balls in each front tire, I dont know if it works or not but I dont have any balance problems.
