Alright, I just did a full on RR SPO w/OTT,Swaped in a 1.6 8V made a custom 2.5 inch exaust popped in a polyshield, Center force II an Im ready for inspection.Everythings runnin great I drive over my girls house wake up the next day and its runnin like $hit. Massive hesitation on the low end but it idles perfect and seems very responsive if its in neutral with quick taps on the throttle but if I accelerate slow it konks out an shuts off.The next day the fuel lines freeze so i put a little gas X and gas line antifreeze in with a nearly full tank.I only used 1/2 of what was recomended for that much.The next week I give it a try and it started right up! Worked great until I drove 2 or 3 blocks An the same dam thing starts up.I mounted the electric fuel pump and a glass filter where the stock filter was so I can see its 1/2 full of green gas X water crap so I figure there cant be that much in there so I pumped all the gas out at the pump then cleared the line at the carb an topped it off with 6 gallons from a different gas station let it run for like a 1/2 hour. No more green $hit but its still doing the same thing if not worse!? I know I should take the tank out and flush it out (mine doesnt have a drain plug) but the gas looks good now and its dam cold outside. If anyone has an advise it woud be GREATLY APPRICIATED!! Im dyin to go wheeling again my trucks been sittin there for 4 years and I just did all this work on it.
