Well, since this forum doesn't get much action anymore I'll do my part and post something.
After about six years of relative inactivity, I put my XJ back into service recently.
I replaced/installed the following:
New water pump
New heater hoses
New radiator hoses
New thermostat
New idler pulley
New serpentine belt
New muffler and tailpipe
New shocks
New steering damper
New rear driveshaft u-joints
New P/S wheel cylinder
New flexible brake hoses
New hard brake lines
New caliper bleeder screws
New fuel tank vent line
New fuel filter
New license plate lamp bulb
New climate control panel bulb
New rear wiper blade
I also fixed the broken antenna connection behind the P/S kick panel, fixed the intermittent low beams/no high beams, fixed/replaced the D/S front door lock rod clip, changed the oil and coolant, bled the brakes and aired up the tires. The spare had less than 5 PSI in it, I'm glad I checked it.
It still runs like it did the day I bought it.
If the floors weren't so rusty, I might get another 200K out of it.
New water pump
New heater hoses
New radiator hoses
New thermostat
New idler pulley
New serpentine belt
New shocks
New steering damper
New fuel filter
