welll... this might b a stupid question but i need to ask it ne way. i may not even b able to get an ansewer but... lets say i need a new rear axle.. and im gonna put 4.10s in it and the front d30....where would i go to find a good axle...d44 or sumthing else thats gonna hold up to 33's (ford 8.8??) and how much can i expect to spend? used? new? junkyard? im pretty much lost about price and where to find one.. please help thank u much
I would look for the 8.8. you can find them with 4.10's already in them, disc brakes, among other things, and it is within a quarter inch of the d35. I believe that the spring perches are realatively close for the YJ swap.
I would also consider somthing other than the ProComp lift you state in your profile. Around here they are known as procrap for good reason: just do a search on them and you will see.
Phil
you can also look for the D44 out of an 87-90 XJ (sprung over)or MJ (sprung under) i bought one for $260.....they will have the metric ton package on them.........or you can get a waggy rear D44 (not sure on the year but search for wbcarver on this site) there have been tons of these swaps done , you can get one for under $200.......search for H8monday if you want to go the 8.8 way, about $300 with most of the disk brake stuff on it....i think he had that on his comp. rig running big meats.......welcome to the world of jeep crap......
later
john
If you need a new rear axel then you are on the right track picking a D44 or 8.8 I like the D44 but that is just me.
Depending on what you want and what you want to spend you have lots of options.
You say you want 4.10's I think that if you are spending the $ to put in a new axle it is worth it to replace the R&P and bearings. Again that is just me, but it is always a bummer to take off new parts to replace worn out "new parts"
If I were you (and I was you.... I have been working on exactly the same project) I would go out and find a junk yard with some old waggies. And get the rear axle from one. It is a D44, 6 lug, 30 spline. And as a rule they are cheap. I got mine for under $150. And here is a tip for you too. While you are under the waggie, grap the front drive shaft. It is a CV shaft. When you put in your new axle you can have that shaft retubed, and use it in the back. WAY cheaper than getting a new custom CV shaft.
I forgot to mention that the rear D44 from a waggie is just about the perfect length for a "small Jeep"
Good luck with your project and keep the board posted.
