Beings I have my CJ2 down for a rebuild I was thinking about locating a set of wider axles. Any suggestions on what to look for that would be a couple inches wider? They need to be right side drop so I can keep the 18 tcase.
Thanks in advance.
Keith
C-Ya.....................kh
Scout or Grand Wag axles. If you get the narrow track GW I think they are both about 58" in rear and 60" wide in front. I think you would have to locate the spring hangers outside the frame to make them fit though, or shorten the front.
Do a search on either axle set. There is a ton of good info from people who know a hell of a lot more than me.
Bill
· Official Historian
you might look at 70's quadratrac cj 7's. i think the narrow track cj7 is still wider than the flat fenders. my axles i took out are 3 hours away otherwise i'd give you that measurement for comparison. with the light weight of the flat fender, you could use quadratrac axles with 2 inch spacers and not overload the bearings. (the april 99 four wheeler magazine contains an article on wheel spacers.)
79/CJ-7/AMC360/TH400/Q-TRAC/d30/d44/33's/RS9000s/Herculiner/Pro-jection 2D
