Just bought an M38A1.
It's equipped with a fresh 350 into a 350/D-18. D-44's both ends with 5.38's and Lock-Rites both ends. It's strong enough to pull up the front wheels in my dirt lot! It just doesn't stop!
The question - they are open knuckle axles, 11" brakes in front - rears not sure of yet. The PO said they are cut down, narrowed. I see the pinion shaft is offset, but doesn't quite line up with the D-18 - off by about an inch or so - and yes, the drive shaft is super short - 10.5"!
The PO claimed he had $3800 in the narrowed axles alone, including the skinny 1.75 springs.
It looks like he might have lied, the knuckle welds look factory. It's time for brake shoes or a disc conversion - it barely slows down when you jump on the brake pedal.
What do you suppose those axles may be from?
He said a shop did it, and he doesn't know the donor.
Scout? Chebby? Any way to tell?
Just what I need, another project!
Thasks,
Thasks,
