auxiliary lamp mounting to a brush guard with no holes
401 Views 3 Replies 1 Participant Last post by  **DONOTDELETE**
Hello. I have a brush guard in the front. There are no holes for off road lamps to be installed. What can I do? Drilling is out because my old bumper has been taken out and the brush guard can not be drilled. Welding is an option but I do not want to go that way. Thank you for your reply.
simple, take a piece of 1 inch aluminum plate, drill a hole the same size as the tubing in your guard. next mark out a nice shape around the hole that would allow two bolts to go thru, one on each side of the hole, cut it out with a bandsaw, then cut directly across the hole so your bolts when drilled will clamp the two pieces together.
sorry for the crappy description but I'm getting pressed for time.
what kind of brush guard do you have?
