/wwwthreads_images/icons/smile.gif That which you have described is one o' them "Oklahoma Fixes"/wwwthreads_images/icons/blush.gif that have been developed to refresh tired and sludgy engines./wwwthreads_images/icons/tongue.gif The ATF particularly affects the close-fitted parts, especially hydraulic lifters, where sludge can inhibit oil flow and the lifters don't want to pump up./wwwthreads_images/icons/tongue.gif This process isn't without risk, as any dislodged sludge can also collect on the screen and slow oil flow to the suction side of the pump./wwwthreads_images/icons/frown.gif That, plus the risk of inadequate lubrication in some high load areas of the engine, makes this process something that I would have reservations about doing to an engine under load on the hiway./wwwthreads_images/icons/tongue.gif I have resurrected a slew of GM diesel cars from the late 70's/early 80's which had been sitting and had LOTS of stuck lifters on startup. The product I used was Berryman's B-22, an oil additive that was only used at fast idle and then only for 20 minutes, after which every thing was drained and then drained again after about 100 miles. The B-22 seemed pretty thin, and was way thinner than ATF. It did, however, work miracles on cars which had been sitting for up to eight years./wwwthreads_images/icons/crazy.gifA little diesel know-how and a good understanding of how to overcome the THREE MAIN screw-ups that GM made in the design of those cars kept me in dirt cheap transportation for quite a few years. Those diesel cars were EVERYWHERE, none running of course./wwwthreads_images/icons/smile.gif
Quadra-Tracs modified While-U-Wait by the crack moonguy/wwwthreads_images/icons/wink.gif Quadra-Trac Team./wwwthreads_images/icons/tongue.gif/wwwthreads_images/icons/smile.gif
