What engine speeds should an AOD typically shift at? I just had the thing serviced for a slow leak – fluid, filter, seal, etc and it now shifts at a much higher RPM than before. First to second is the most noticeable. Now it drops into second around 2200/2400 where as before it may have been 1800/1900 or so. I’m not complaining (yet) it shifts fine and I suppose I could use the extra revs towing. I’m just curious what would be typical for an AOD.
Riff raff
I just tested my 86 on a run into town and it seems to confirm your 1900 at light throttle pressure. It upshifts at 4500 at WOT. 192,000 miles on the AOD.
Sixlitre
