I am considering swapping to a carburated ford 302/351. I am pretty much commited to running a ford motor because i have a ford NP 435 that i really like, and spent way too much money on. Anyone with experience or advice please inform me
Brandon
[email protected]
a friend and i put a 351 into a cj-5 with a ford t-18.
even with a spring-over, he still had to get a custom oil pan(it hit the dana 60 in the front). other than that, it was pretty easy.. a lot of the older jeeps with v-8 used ford ignition anyway, so try to get a wiring harness from one of those and it will look stock.
~~Elusive~~
the 302 or 351 windsor is perfect for a jeep swap because the Distributor is in the front and you dont have to bash your fire wall to fit it in like a chevy. Yes, you need to buy the bronco pan and oil pick up to clear the front Pumpkin.
the 302 and 351 windsor make good wheeling engines. the 351 can be poked and stroled to 412-416 cubes with just a little work. 302s are cheap, plentiful, and have excellent aftermarket support. the 351 is a little more to build, but will provide loads of smooth low end grunt with a few minor mods.
my favorite small block ford is the 351 cleveland. these are not for rockcrawling. they were designed to be a high rpm hp engine. they are by far one of the best for mud though. a good cam, intake, and a small bump in compression and voila, instant mud bogging monster.
dan
I'm working on a 351 swap into my '76 cj7. I looked all over for an oil pan and finilly found one from Ford SVO. Comes with a new pickup, gasket, and dipsitck. I'll have to shorten the dipstick, for some reason it sticks up about 8" too high. I'm using the factory 3-speed transmission but in hindsight I should have went with the NP435.
Thanks for the info. Y'all kinda conferred what i had already found out. Advance Adapters has the oil pan i would need and told me what year bellhousing to look for to be able to keep my factory hydraulic master cylinder.
Did i also hear right that the 302 is about 100 pounds lighter that a chevy 350?
thanks
