1 - 9 of 9 Posts
Are you talking clearance from the ground up, or clearance between the plate and the tranny?? If you want tranny to plate clearance, I have seen people weld steel bushings in for extra room on applications like that.
MattYJ
89YJ 4.2 5"lft 33"Firehawk ATX
Robert, I don't have any drawings, but when I clocked my Dana 300 I bolted it back together, marked the area on the right side that
now hung down to far, took it back apart and cut that part off. I then cut a piece of flat stock and welded it in place. How much you can
cut out is dependent on how much you clock the xfercase.
Gary
You need to talk to Jeepskate. I was looking to due the same thing and he posted that he was going to due it and take pictures since his Jeep is bodyless. I do not know if he has done yet or not. Check with him.
Would a flat skid-plate be the best? or one with angles or "ramps" be better?
my thought being a flat plate would have too be thicker to support the same weight as one with many smaller pieces put together, correct? The overall idea being a skid plate that could support the Jeep in a high center situation, but also one that will slide over an obstical both forward and reverse.
That is one clean crossmember! I really like the tubular setup for strength and the plate to act as a skidplate
Jeff
'83 Toyota long bed
5" lift, YJ front springs
1 - 9 of 9 Posts
