I have a 94 4.0L motor out of a YJ Wrangler. I purchased a AA Bellhousing and a LUK Clutch kit for the 94 Wrangler motor. I got out the orginal pilot bearing from the 94 motor. The pilot bushings sent from AA were of wrong size. I called and they are sending me the right one (ID and OD), I hope. Am I going to have any problems with the length of the input shaft when I mated the the 4spd T176 to this 4.0L crankshaft? There was only one pilot bearing/bushing to take out of the crank right? AA said there might be two bearings/bushings with "late model" engines? Also, they say if the flywheel is less than 1 inch thick, this will also create problems. I had my machined, now I am worried. I have never done this before, any input, comments, or suggestions would be appreciated. Thanks.
85 CJ8 Undergoing Frame-up Modifications w/4.0 standing by for transplant w/T176/Dana300 - Lookin for aluminum or chrome 15x8 spoke wheels to fit CJ.
Have you looked at solving the CPS problem? You can either machine the 176 bell to accept the sensor, or get a kit that relocates it onto the balancer. Brendan
Proud owner of the world's best running Carter BBD
Since he is using an AA bellhousing it is probably the one with a window already in it for the CPS.
'75 CJ5,258 w/Howell EFI,T18a,4.27's,33's,On-board air,Warn 8274
Yes, the AA bellhousing is machined for the sensor, not a problem. It needs to be gapped to 30 thousandths according the the AA instructions.
