I'm not happy with the entire rebuild process. I started out thinking of my tintop as a simple vehicle (that much is true), but really underestimated what I was getting into. I had a lot of get advice from the get-go, so I started off buying b-ringed front axles, 4.57 Yukon ring and pinions for the front and rear, and made the decision to go with Spidertrax disk brakes with Pork Barrel Line Lockers for the steep stops. The general consensus seemed to be that YJ springs and SPOA was the way to go, so I opted for the Trail Tough hangers with missing links. Jim Shrake came along with his steel, so I have one of his front bumpers coming in.
That kind of stuff is coming along fine, though it has taken almost a year to get the parts together, mainly because I allowed myself to get sidetracked into other areas. My engine had almost 200,000 miles on it (my miles, but still hard), so I ended up buying a replacement and building it up. I mentioned sidetracked: that means replacement engine, dual Weber carbs, Hawk cam, fresh head, new waterpump, gaskets, motor mounts, RRO GM alternator kit, headers, etc., plus all of the labor involved in that.
Along the way my perfect tintop became a rustbucket. Rust was hidden in the front bumper mounts, under the plastic rocker covers, and under the wheel flares. I also found rust under my rear door hinges and around the fuel filler neck. It probably wasn't as bad as it could have been after 15 years, but it was another expensive and time consuming diversion.
And then of course, there was looking at all of your good looking vehicles. So more diversions to install Recaro seats and Swift GTI steering wheels, add shifter sheets, and cool shift knobs.
So, a year later she is sitting on her own wheels again, still waiting for crossover steering and a traction bar, still waiting for driveshaft spacers and extended slip yokes. still waiting for extended shocks, for a new windshield and new carpet and getting the dash put back together and hopefully having the a/c working again and going into the paint shop for a shiny new coat.
In the end the makeover and build will have cost more than the rig did off the new car lot (by quite a bit). Hopefully she will be a bit more capable, a bit more distinctive, and mine. Yes, thinking it through is really important!!
