Guest
·Like i said,ideas....Anyone ever checked into the availabilty of the quick disconnect steering wheels? and a idea i had for floor shifters,have it cut below
boot level a bit,a threaded sleeve added,and end of shifter threaded.Park where it cant go forward.tree,building,etc.Put it in low and remove shifter.Course you would need
a lock nut on it to keep it tight when installed.Might be a pain at the grocery store,but no shifter at night or when its going to be parked
awhile would certainly make me forget trying to steal it.(if i did that,which i dont)
I saw a guy once who modified a parking brake pedal,he disabled the ratchet in it some way,drilled a hole thru it and used a pin,to set brake
install pin,push it down,remove pin,pedal then flopped free.No i have no idea how he did it,was years ago.If you are a siren fan,what about
a siren connected to a motion sensor,or two or three,under drivers seat,hood,etc,but hooked up to a hidden motorcycle battery instead of
the Jeeps battery,just in case they want to steal parts and try cutting battery cables?Spoke wheels?what about a big logging chain
locked between 2 wheels?
I know ! when in a motel,and parked in front of your door,run your winch cable loosly under door and connect
it to your bed.. LOL Sorry, just had to add that..Cant be serious all the time..
