Local junkyard going out of business today, everything you can carry in a wheelbarrow $25
I found three cast iron GM manual transmission already pulled. look like late 70's mid 80's
question, how many cast irons are there, what could these be?
brownbagg
Those should be the SM 465. They are a good tranny with a little bit lower first than the t-18 but when you
add the adapter they are quite a bit longer because of the way the cluster shaft retainer is designed. If
you can pick 'em cheap, go for it. Nickmil.
I had to answer quick because they had three hours till closing for good but, I found what they was. Two of them was saginaw three speed from a car and the other was a muince three speed from a car. I was hoping they was something good because they was already pulled, I could of snatch all three for $25, and no they wasn't any 18 i look the place over for it. Found three d60, It just that they are way to big for my cj2, I stick with my 44. thank for the help.
brownbagg
