I was going to stay out of this until sickdog waded in, now I can't resist making him pull his hair out...
First off, Miller bought out Hobart a while back, and Hobart welders are made with mostly Miller parts now.
I have a Hobart 175 Handler in my 'Toy Truck', and it works just fine, just a well as the Miller 185 at the shop, cost half as much and is less than half the size of the 185.
(I didn't want to give too much for it, It only gets used a few times a year)
The ship yards that produce nuclear submarines and nuclear powered aircraft carriers use Hobart welders, so the statement about Hobart being junk should be taken with a grain (or pound) of salt...
We have Hobart, Miller and Lincoln at the different shops, and our CERTIFIED WELDERS that weld all day long every day, on every imaginable type of metal, say there isn't a nickel worth of difference in the small welders for general use.
The two types of common welding are...
CONSTANT VOLTAGE. MIG, TIG, ECT...
CONSTANT AMPERAGE. So called 'Stick' welding.
Aluminum windings are going to affect Constant Amperage more than Constant Voltage welding.
There are two basic kinds of welders....
TRANSFORMER.
All of the little MIG welders are transformer types, as are most of the stick welders.
Current is taken from the available power lines, and Converted/ Transformed into the Amperage/ Voltage needed for the particular kind of welding needed.
GENERATOR.
All of the 'Stand Alone' Welders used in the field are Generator types. They use an electric motor or Internal combustion engine of some sort to turn an Electrical Generator to produce the current necessary for welding.
The only difference I can tell between the Aluminum wound transformers and the Copper wound transformers is the Copper has a little longer duty cycle.
(DUTY CYCLE: How long you can weld at any given amperage/ voltage before the transformer trips the thermal protection and stops welding.)
The Transformer will build up heat while you are welding. At some point, the thermal breaker will open, and allow the transformer to cool down. The amount of time you get to weld is the 'DUTY CYCLE'.
If you are going to do mostly small to medium size upgrades...
(welding bumpers, tabs to your frame, making brackets, ect. are all small jobs)
Then just about any kind of the smaller MIG welders will work.
Your duty cycles will be short, the material you are going to work with will be thin, and a MIG welder is easy to learn with.
If you are going to do larger than about 1/2" very often, it would be a good idea for you to go ahead and get a large generator type welder. You can do larger stuff on a small welder, but it will take lots of practice and lots of passes over the weld.
If you want to do mostly auto body work, most of the guys will use DAYTONA welders first, and little Lincoln second. (transformer type welders)
If you want to do mostly production welding, most of the guys will ask for MILLER 250, 250X or MILLER 251. (transformer type welders)
If the guys in the kit fab shop want a new welder, they say the Lincoln 255 will do more tricks. (transformer type)
If the guys in the HEAVY fab shop want a new welder, they will almost always ask for those HUGE Hobart Generator type welders. They just love those things.
We had too may 'Personal Projects' coming into the fab shops, so a couple of years ago we gave away the little 110 V. Miller welders to the shop guys for Christmas...
'Personal Projects' have dropped off to nearly zero since then, and the guys all love their welders, and make all kinds of cool stuff with them.
Don't kid yourself, there have been more top quality hot rods built with 110 V. welders than anything else...
I've heard good things about the little Century and Chicago Electric welders, and they are cheap enough to buy one every week!
The ones I buy the most are...(Small: Under 200 Amps rated output)
Miller, they come with regulator and all hardware to get you welding, a little expensive, but will sell used for nearly new prices. They really hold their value.
The only draw back to the Miller line of small welders is there is no fine tuning of the output voltage. That's only a problem if you do very thin sheet metal...
They are also pretty large if you get into anything above the 110 Volt models...
The Miller larger machines (250, 250X, 251, ect.) are EXCELLENT for production work.
Unlike Lincoln, if you get your Miller welder set to weld a certain type/ thickness of metal, the machine won't 'Drift' on you. It will stay at that output setting until you turn the knob, doesn't matter if it's three hours or three years later... The setting will stay where you put it.
Hobart, they come with regulator and all hardware to get you welding, very reasonably priced.
The 135 Handler (110 V.) sells for about $430, The 175 Handler (220 Volt) sells for around $525 around here.
The only draw back to the Hobart line of small welders is there is no fine tuning of the output voltage. That's only a problem if you do very thin sheet metal...
Daytona, They come with regulator and all hardware to get you welding, very reasonably priced, and good customer service.
The little 110 V. Daytona 100 and Daytona 110 is the choice of body men around here because of the voltage output control.
I've seen these guys weld together both steel and aluminum soda cans with out burning through... They really love the little Daytona around here...
The second choice of the guys in the body shop is Lincoln because of the voltage output control.
The small Lincolns don't have any of the stuff the small Millers have.
With Lincoln you will have to buy the gas regulator separately, if you intend to use a spool gun (for aluminum among other things) that's a separate purchase, ect.
Lincoln 255 is preferred by the guys in the chassis fab shop. They rarely weld anything more than 1/4 inch, it will ramp down to do sheet metal, is supposed to be digital controlled voltage, but you still have to buy extra gadgets to get it to do what a Miller will do right out of the box.
