I wanna change from the AX-5 tranny to the AX-15. Anyone know where I can get detailed info on the swap? I'm pretty new at this stuff.
absaroka
I just looked at a spec sheet in a magazine. If their info is correct the AX-15 is 6.5" longer than the AX-5. I didn't think there was any difference in length. If this is the case, then it will be a little more involved than I originally thought. That would require you to change your driveshaft lengths. I don't think this information is accurate but you might want to check this out a little more. My understanding was that the differences were internal, larger journals etc. This magazine says the AX-15 is 16.75" long through the case. That seems wrong, that would make the AX-15 the longest case i ever heard of for a manual trans outside the realm of big rigs.
