Another Quick Weber Question?
2.4K views 12 replies 5 participants last post by  Sarge
Waaats the difference between DGAS and DGAV?
I know the A=water choke and E=electric, just havent figured out the SSSSSS and VVVVVV on the end.....
Also is the 601 a 32/32 or a 32/36 out of the box?
( yep, the smog nazi's have been kicked outa my county )
NO MORE E-CHECK IN MONTGOMERY COUNTY, OHIO after DEC 31st
DocZook, looking around for carb, GRS-II T-Case and lockers.
87' Wide Body High Top U.N.Samurai-JX
New JFE 1.3 Performance Engine
RV-2 Cam - Bored 40 over w/flatops
Flowmaster Performance Exaust
Red Ryder Soft Valved Extended Shocks
Trailmaster 5" Lift w/Rugged Trail Helpers
31 X 11.50 Super Swampers on Ford 8"s w/1.5 spacers
Centerforce Dual Friction Clutch
[ QUOTE ]
[/ QUOTE ]
doczook,
I hear they are doing the same in butler county as well, i'm sure they will figure out a new way to cause us headaches.
nolan
#3 ·
[ QUOTE ]
[/ QUOTE ]
I live in Clark and I think it will be gone here as well. To late for me this time around as I have to get tags next month /ubbthreads/images/graemlins/cussing.gif /ubbthreads/images/graemlins/chair.gif
Be NICE later on though!!!!!!!!! /ubbthreads/images/graemlins/40BEER.gif
#4 ·
DGEV-32/32 or 32/36 electric choke
DGAV-32/32 or 32/36 water choke
DGAS-38/38 sycnronous, water or electric depending upon series: 33B1, 44k ect. There are some new versions with 30mm venturi's , watch out for these since the venturi's are too large for engines under 1800cc's unless it's built very heavily with very high compression/flow levels. Most 38's use 27mm venturis which is perfect for built 1.3-1.6L engines.
32/32 carbs are listed either as 32DGAV5A for the manual choke or 32DGEV/AV for water/electric models . A lot of the older early model 32's are being shipped out as 32/36's by mistake lately, keep an eye on what you buy if you get one from a vendor . Most were original equipment models for BMW's and Fiats.
The K-601 kit should be the 32/36DG*V with open air element. Do not get one with the stock (K-600) air cleaner adapter, they inhibit air flow terribly. Either use the taller 2 5/8" air cleaner or the 600cfm Ramflo . I have in stock right now the following:
Rebuilt/modified 32/36DGEV w/intake
Modified 38DGES electric choke w/intake
36/36DCNVA manual choke w/intake
Sarge
#5 ·
N0lan, We were just saying that same thing, It's just seems like it's too good to be true! The government usually never ends a program without having something else to impliment and extort....errrm, I mean replace it, I keep hearing more about new federal air standards comming and newly formulated soy bean gasolene... So they will probably hammer us more at the pump and have some kind of portable infared currency sucking smog detector in every police car...statewide! eeewwwwwww!
(In a Year or two, you might hear.... Hey Sarge, These Soy Beans clogged up my webber!)
Sarge... You saved my %$# this time, The Webber I was looking at was packaged as a k-601 DGAV but had the 051b part number meaning it was only a 32/32.... Thanks! I did spend an hour and a half in search, reading all your past posts before I asked. I'm dropping you an E-mail now....
DocZook
#6 ·
051B is just a variation series, still should be a 32/36 . It should be stamped on the side of the base to identify it's throat sizes. Most of the 32/32's are strictly marked as such:
32DGAV
32DGEV
32DGAV5A (manual choke)
Sarge
#7 ·
Sarge, I tried to phone you last night, but you were out, If you would, check your email, The more I learn, I think the highly modified Weber 38 DGAS with the modified intake is the only way to go for what I have going here.
I dont mind mounting a holly electric fuel pump and getting the regulator.
I got to do something quick, there is a kid on a riding mower wanting to race me!
DocZook
#9 ·
[ QUOTE ]
Tried to pull the phone # off the caller id but it wouldn't work , so it's phone tag-
You're it!
The carb is yours if you want it , I'll be in and out the next couple of days with work/weather...
Sarge
[/ QUOTE ]
Yesss! You know I want it, It's mine, mInE, MINE, all M I N E! Soon as you can get it here! But I understand you must take care of things down at the Nookular Plant first...:) naw joe, It's Nuclear. Sarge, I'm headed up to the parts store to see about the pump and regulator...
I was on the RED PHONE Sarge, It don't leave much of a trail. I sent you the number to my Signal Corps GI Phone which is a land wire based unit, should you become "IT" again! (smile)
DocZook /ubbthreads/images/graemlins/yourock.gif
#10 ·
LOL< not currently in the Nuke this year, got a bit too hot last outing ... gotta wait awhile before I can go back.
I'll give you a buzz later today, gotta finish swapping trannies and figure out a noise in my tcase so I can go to work Monday...
Sarge
#11 ·
Hey Sarge, I finally got the Weber DGES 38/38 bolted on this morning and took it for a test drive, then another test drive, I did not want to stop test driving it! The difference was night and day and for the first time ever, I was passing cars left and right on the highway, and not just the ones comming from the oppisite direction! WoW! Then I opened it up on old Snake Road. It felt like I was driving a porsche as I was going through the gears. I topped a small hill and went airborn for a couple of seconds, So did the forest ranger behind me! I thought he wanted to play, but he took the horse trail, and I went for the creek bed...I'm impressed with your magic! Everything was preset just right!
DocZook
#12 ·
[ QUOTE ]
DocZook
[/ QUOTE ]
/ubbthreads/images/graemlins/grin.gif
Damn cocky kids! You oughta get a 72" mower deck and take away some of his business. That'd show 'im!!!
