Short wheel base ,but i do have a problem, its 2wd, auto trans???
Discussion Starter · #2 · (Edited)
Cluncking rear end
It clunks on up and down shifts ,,more so on the downs.,, but not always but 75% of the time and its the same sound on up shifts sometimes, it is comming from the rear of the truck,, u- joints seem to be ok? Any help or ideas?? Dex most always at slow speed 25--40 mph,, any help ??? [email protected] im starting to pull a 12' box pop up camper and i dont want to get stranded on hwy if something lets go, yes the gear lube is full. it did this before i started my pulls with camper
Now you're in the right place :D
Ujoints would be my suggestion. Looks can be deceiving. The needle bearings in the cap get dried out and eventually will grenade.
I'd also pull the rear diff and have a look.
Has the noise gotten worse or has it always been consistent? I just ask because I've got a good clunk that's fairly regular.
clunks sound in the rear
yes it has gottin worse,, sounds are in rear but mostly at right rear, as i bhear it but only about 90 % of the time?? only at up and down shifts, automatic trans. but yes ill install new u joints and drain and pull off the the cover and look at gears? thanks DEX
