well i have been looking around for a tj and i wanted to get the 6 cylinder but it seems that all i see is 4 cylinders. if i have to get a 4 cylinder i will but i have heard they are kinda wimpy on the freeway, what kinda of gas milage do you stock tj 4 cyclinder get? and what kind of mods can be done to get the best possable milage out of it?
There is only one modification that will significantly improve the gas mileage of a SWB, and that's reducing your cruising speed.
In case you haven't noticed, Jeeps have the aerodynamic properties of a cow barn. Drag increases with the SQUARE of the speed. For example, 70mph is 40% faster than 50mph, but aerodynamic drag is 96% more - almost DOUBLE! And aerodynamic drag is BY FAR the biggest factor which you can control.
Fooling around with the engine might gain you a few percentage points, but on a modern vehicle it's not a given, maybe not even likely. If you're going to get a Jeep, you should consider getting into a Jeepin' frame of mind. Nothing you can do will get you into econobox territory. Other than hooking the winch cable to the back of an 18-wheeler.
Don't purchase a 4 cylinder. Neither the 6 nor 4 are economy savers. Don't purchase a Jeep for your daily driver, you'll fill them up with gas every other day.
Like the others said, its a jeep, not a yugo!
I'd keep looking for a 6 cyl. I don't think they ever made a TJ 4 cyl with a dana 44 as the rear axle (metal screw in plug in the dif cover vs. rubber push in plug) anyways, giving yet another advantage to finding a 6 cyl.
I once had a 78 CJ-5 with a 360 out of a AMX (11to1compression stock) put a Holley Spreadbore on it along with a t18 tranny from a honjo & unhooked the secondary linkage on the carb & got 28 miles to the gallon,,, had lots of power to boot ,,,
Ex wife
got that Jeep ,,,, Damn I miss that Jeep
97 cherokee, 6cyl, auto, pretty stock, City =17-18MPG,,,Highway 20-24mpg...Like they said before speed kills mpg when you drive a brick. Running the AC in the city will cost about one mpg,,,highway the same.
After driveing a pick up that got 10-11 this is pure heaven,,,,,Oh yes the above mileage is with a gentle toe, when you go to the stop light drag races it (mpg) all goes out the tail pipe like a shot. Jeeps, Jeeps, gotta love um.
