Did some work on the XJ this weekend. I knew I had a manifold crack so I removed the manifolds and welded the exhaust manifold. It was cracked almost all the way around one of the two tubes welded to the collector. I believe this was due to a broken engine mount. I have discovered that the engine mounts do not hold up very well on these things. So I replaced the engine mount and decided to fill the gap between the rubber part of the mount and the limiting strap with JB Weld to limit how much the mount will flex. I was sorta in a hurry to get it fixed so I didn't let the JB weld cure before installing the mount. Also, I wanted it to cure with the bolts tight on the mount so it would be properly fitted when cured. Well even though JB Weld is thick and quite sticky, I found out the hard way it will flow out of something like molasses until it cures for quite some time. It made quite a mess in the garage floor and on top of my front diff. Next time I won't be in a hurry and I will tape up the sides to prevent the stuff running out. So anyway, while I had it apart I also installed some Ford Mustang fuel injectors I got on E-fence for $20. These injectors are 19lb/hr units and have 4 holes in the nozzle instead of one in our Jeep nozzles. All was well until I turned the key on. The damn thing had a leaky injector. I took it back apart and changed the seal that had been pinched on installation. I then repeated the procedure two more times as two other injectors got pinched on installation. These things are not easy to install without pinching the seals. I did lube the seals with vaseline before installation. It is just hard to align the fuel rail on the injectors and push it down without pinching a seal. Anyway I managed to get it all back together and I will check the mileage to see if the Ford injectors help mileage any. A note about the injectors: they can be had cheap, I got mine for a $20, they are a direct replacement, they are identical to the Jeep injectors in how they fit. If you replace them replace the seals and I recommend buying a few extra seals just in case you pinch one or more on installation. BTW if anybody needs a set of good used injectors they are a gimme, just pay shipping.
