Re: Adjustable cam sprocket, how\'s yours?
Ok, let's see if my tired mind is still working . Put your degree wheel on the crank, set the thing on one cylinder at TDC with a stop tool . Make sure the cam is also at TDC for that cylinder , easier if you use #1 and set the timing marks at 6 on the cam , 12 on the crank . Now, your are not going to be dead accurate since the cam sprocket , ect , can be off a degree or two and that compounds onto the cam timing in a accumulated manner , but it does help to find a baseline . With the timing belt off and all the rockers loosened to the point of no drag you can rotate the cam and read the height of lift of each lobe . Multiply that by 1.6 as the ratio , and that is total cam lift . Duration is fun ! With the timing belt on and set to tension , remove the cylinder stop and rotate the engine to get the duration figures . Most cam's advertised lift/duration specs are measured at .050" of valve lift , this is a bit more accurate in determining overall engine effect of the cam . You can find the point at which the lobe starts to open the valve , when it stops on the downstroke , and the overlap between TDC and the cam's duration of lift . Hope you understand all this , there are some better and maybe more clear instructions from some of the cam manufacturers online .
Sarge
