AAhhh! Now what?
368 Views 4 Replies 2 Participants Last post by  lynn
Hey all,
I just installed my 304 in my 84 CJ7. I noticed that I busted the oil dipstick tube. Right at where it goes into the block. Now What??????? How do I get it out?
Brian "A4x4jeeper"
http://www.jerseywheelers.org/
Run a tap in it then pull it out with a vice grip???? or run the
tap in and then run a bolt in just a few threads then a vice-grip????
I'm sure some one got a better idea/wwwthreads_images/icons/smile.gif
See less See more
There isnt much of the tube showing...lol.. I would hate to have to pull than pan.
Brian "A4x4jeeper"
Same thing happened to my 304. I had to force a bolt into the remaining part of the tube, then from below the jeep, grabbed the bolt with small vice-grips, then using hammer and long screwdriver, pounded the sucker up and out. It really will pop out - there's nothing holding it in other than the bubble in the tube as it goes down into the pan. When I installed a new dipstick, I added a "brace" that attached with a small hose clamp to a valve cover bolt to help hold it and keep it from vibrating. Been working good so far!
Keep on Jeepin'
Scott
Got a slide hammer? Do the bolt thing previously described, but, weld a nut to the top of the bolt first. Thread the bolt into the tube,then thread the slide hammer end into the nut welded to the top of the bolt. A couple of taps with the slide, it should come out.
(Slide hammer is on my Christmas list...)
Lynn
'71/'48/'97
