Helping dad get his '97 Blazer 4.3L running right. The engine lopes at idle and it can't get out of it's own way when accelerating from a stop.
Got three codes read at AutoZone:
P0102 - MAF - What value am I reading for? Volts or resistance? I get 0.00v on both black/pink & black/yellow. Forgot to write down resistance value.
P0300 - Random cylinder misfire - could be spark plug wires. They weren't replaced with the plugs. Can I test for resistance?? Is there a standard reading to compare to?
P0440 - EVAP - hoping a new gas cap will fix this. Current one's rubber seal is dried and cracked. Also, what does the evap canister look like? Where is it? If gasp cap doesn't fix, what next?
Pulled out the multimeter...
Problem #1 - Reference voltage for MAF 6.00v
I'm thinking there's a short in the circuit. I have continuity in the black & pink wires. But no continuity in the black and yellow wires. I cannot find a wiring diagram that includes the MAF sensor circuit. I'm flying blind on tracking the wiring. Where can I look? My Haynes manual is of no help in regards to a diagram. Is Chilton's better without jumping to big bucks for the GM manual (I'm on the road here without normal internet/comm resources)
For numbers my MAP sensor reference voltage on grey & black is 5.0v so that is good. I tried reading the MAP sensor signal voltage but I need to get alligator clips to use in there instead of the probes. It's a tough angle to see and hold with the engine running.
IAT reference voltage was 5.0v, good. I need to double check the resistance of the sensor, but I believe it dropped from 2.24 to 1.93 between ambient and idling at temp.
Any help with this would be great. Only in town a coupe days and helping dad out as much as I can. Thanks!
