\'95YJ Rear Shock mounts
The bottom rear shock mounts on my '95 YJ keep breaking/ripping off. I've rewelded, reinforced, etc. Does anyone have a bullet proof system for attaching these things? What about welding a shock bolt onto the plate under the springs that the u-bolts go through? (I have the usual spring under system.)
--Tucker '95YJ, 3"RoughCountry, 325/60R/15BFG,10"rims
Re: \'95YJ Rear Shock mounts
It sounds like your shocks aren't long enough! The only reason for the shock mounts to rip off the axle is weight/flex is putting too much stress on the mount. Never seen it happen before with the correct length shocks. If this is the case, a CJ style shock mount (on the spring plate) won't help. Check it out by unbolting the shocks and jacking up the frame until you lift a wheel off the ground. If you can't easily extend the shock and slip the bolt through it, that is your problem.
Mike H.
1983 CJ-7 Laredo
1999 Dakota 4x4
