Greetings folks,
I just found your boards and find them to be great. I already picked a few things up, thanks.
A 92 XJ sport fell in my lap. Lifted with a 2-3" skyjacker. (unsure but I notice they have very few options, guessing) Truck run great. Hit a bump over 35mph, even a small little bump, the front end feels like its comin off. Slow down hang on tight it settles and I'm off again. Mind you I can drive at 50-55 flawlessly though to test was tricky. My question is.....Pitman drop perhaps? I know very little, but I'm learning and that seemed a good start. I have no other steering problems so I'm unsure if I should even consider caster angle or any of the other options. No noises no problem what so ever till a bump.
Sorry to be winded. I would appreciate any help you can offer. Thanks again for your time. Have a great day.
The drop pitman arm is a remedie against bump-steer. It might help, but you have a very mild lift so I doubt the benefits. The solution to your problem lies in replacing worn components, right tire pressure and wheel alignment.
well folks. I am going to start with the bushing on my trac bar. Then the damnper. Your input was great. I appreciate the time spent answering.
And sometimes the combination of imbalanced wheels and worn shocks can also generate quite a wobble.
