Guest
·\'91 K2500 no start
Hi,
Need some help. Just put a reman 350 into my truck five days ago. Initial start-up went fine. Day one, truck ran and started fine. Day two, truck cranked longer than usual before firing up. Day three, truck cranked for aprox. 10 seconds three separate times before firing up...after the engine was warm it started fine...let the truck sit for about 3 hours, then tried to restart, cranked but no fire. ( the key was still on) I popped the hood and started to pull a plug wire when i heard a popping/hissing and saw smoke then black goop ooze from the bottom of the coil.
I have since: replaced the coil, replaced the ign. module, and then replaced the dist. (which was replaced when I did the motor).
The coil has 12.7 v at the black connector with the key on.
What now?
Help
Russ
Hi,
What now?
Help
Russ
