I replaced my BA-10 with a TF-727. I put a NP-208J behind it. The 208 bolts up, has a fixed rear yolk, and is a hell of a lot stronger. However, it hangs down though the skidplate 2"
I've got to do something about that!
The swap cost me around $1000 total. $500 for the tranny, $150 for the x-case, $100 for a shifter, plus driveshaft mods and other odds-n-ends.
What it took:
*TF-727 from '86 G-Wagon (with torque converter)
*Flywheel from '84 CJ-7 with 258/TF-999 combonation
*Starter for an '86 G-Wagon (starters go by trannys, not by engines)
*Starter solenoid for '86 G-Wagon, and some funky wiring.
*Kick-down linkage from '76 DJ-5d with 232/TF-727 combonation. If you can just get a good look at what this does, you can easily hand-bend your own if you get a little creative.
*Transmission cooler and hoses.
*Driveshaft mods. The front diveshaft had to be
shortened ever-so-slightly. The rear driveshaft was a cut-down XJ piece from a junkyard ('86 XJ with "select-trac" so it had the NP-228 x-case and correct driveshaft parts). I had them install all-new U-joints with zerk fittings that stick out of each cap for easy greasing.
*Shifter. I screwed up here and got the B&M Z-gate shifter. It's only suitable for cars (too short). The B&M Megashifter is the truck model. (I'll make a tranny-mounted, linkage-style shifter when I get some fabrication tools). I got the J-10 x-case shifter and mix-matched and fabbed up some parts to make it work- still very tough to shift though.
An AMC V-8 is in the works
