Guest
·I had to leave my wrangler sitting for 4 months (running fine before)
when I came back, it wouldn't start. I changed the fule filter, disconnected
the fule line under the hood and tried starting it to check the fule
pump, sprayed starter fluid in the air intake, changed the air filter,
and removed a sparkplug and grounded it to check for spark. Everything
above worked great, I did notice that the spark plugs were dry when
I took them out which made me think they weren't getting any fule.
I took it in to be serviced and was told it needed a new ignition coil,
manifold, crank sensor, distributor cap, and roter. It seems to me
like I wouldn't have a spark if I needed half that. Any help would
be appreciated
be appreciated
