85 Suburban vibration?
1.1K views 6 replies 3 participants last post by  **DONOTDELETE**
Hi guys. I own a 85 GMC Suburban 3/4 ton two wheel drive. It has the 400 transmission and a 454 motor. It has a oscilating vibration at about 67 m.p.h. on up. I feel it in the floor and in the seat. I can run it up to 70 m.p.h. and take it out of gear and it stops. When stopped I can put the truck in park and get the r.p.m.'s up to where they were at 70 m.p.h. and there is no vibration. I can put the truck in 1st or 2nd and get the r.p.m.'s up to where they were at 70 m.p.h. and there is no vibration. I have put new U-joints on it and it still has the vibration. I have looked at the drive shaft for a thrown weight and did not see anything. I bought the truck like this thinking it was the U-joints so I don't know how long it has had the vibration. Man if you could help me out here Id be very thankful!! Mark
#3 ·
Mine does the same thing and it didn't start till after I replaced the 700R4/208 with the TH400/241. My dad's 2wd truck with a th400 did it too and my g/f's folks 1/2 ton sub with a 700 does it too.
Edit: same rear driveline too for both combos too
#5 ·
I have been trying to pay more attention to it and listen a little closer and it appears that the oscilating vibration quickens under accelleration. When Im ascending an incline such as an overpass the r.p.m.'s pick up to maintain a speed of 73 m.p.h.. When the r.p.m.'s pick up the vibration quickens. Once I reach the crest of the incline the r.p.m.'s return to where they were and the vibration returns or slows to where it was. What do you guys think?
Thanks, Mark
#7 ·
on my vibe it only started after putting the tranny, t-case and crossmember in otherwise it is the same 1 piece driveline, rims, tres, everything. It is possible in my case that tranny mounts being bad since I did use the crossmemeber/ mounts that I got form the junkyard with the tranny combo
