I would certainly check for a vacuum leak. If you have the Carter BBD carb on it check the metering pin. If it is extended out completely, it indicates a vacuum leak because it's trying richen the mixture. You could try spraying carb/choke cleaner at the base of the carb or intake manifold looking for changes in idle speed too.
That would be my first check. Also check your PCV system.
My 2 cents.
CJ8George
o[[[[o
My 2 cents.
CJ8George
o[[[[o
