\'81 CJ7 4cyl to 6cyl swap, hydraulic clutch solution needed
Hi,
I have a 1981 CJ7 with the GM 150 4cylinder and a HYDRAULIC clutch. I want to swap in a used
258 6cyl but they all seem to have MECHANICAL clutch linkages. I have read the GM bell housing
won't swap to the 258. Is there a cheap and easy solution here on the clutch linkage?
Is there a clutch slave cylinder adaptor for the 258 bell housing? Experienced advise appreciated.
Jim R
Reno, Nevada
[email protected]
Reno, NV 89434 home ph 775-356-5381
Re: \'81 CJ7 4cyl to 6cyl swap, hydraulic clutch solution needed
I have seen a very clean hydraulic setup on a Jeep here locally, in fact I'm thinking of duplicating it myself. Check it out at:
http://www.monsterslayer.com/jeep, it's Jaffer's page.
Brad
Get active or get locked out, the choice is yours.
