i got my stuff to convert my front 44 to 8 lug to go allong with the 10.25 rear i have now ready to swap in.
the good thing is year parts allow me to use my 1/2 ton shafts and hubs.
so, what are these 2 metal rings i have. use the twin piston caliper there on for a size reference. how mnay should i have, and where do they go?
<img src=http://tellico.off-road.com/wwwthreads_uploads/855502-Mvc-033s.jpg>
on another note, all i need are wheels!
the 10.25 is welded, and has a new 1350 series yoke on it(to go allong with my driveshaft), i redid the entire break system on the rear axle, and even went and got spring plates and new U bolts for it. all i need are rims, and then i need to have my D shaft shortened a tad.
<img src=http://www.superford.org/registry/users/372/1549/1025front.jpg>
<img src=http://www.superford.org/registry/users/372/1549/1025pig.jpg>
<img src=http://www.superford.org/registry/users/372/1549/1350yoke.jpg>
<img src=http://www.superford.org/registry/users/372/1549/8lugfront.jpg>
It should go over the outer wheel bearing lock nut. I don't know what purpose it serves, cuz a lot of trucks I've worked on don't have them. I guess they just throw them away. Maybe it just prevents the hub lock from rubbing against the outer lock nut.
When you say welded, do you mean the spiders?
The parts look similar to what is being shown as a "front hub grease retainer". In the view, it looks like it is one of the innermost pieces toward the spindle. And they show there would be one per side.
